- Micro-holes machining - economical options
I need to machine through holes, 0.25mm diameter, approx. 2.5mm deep
I need to machine approx. 4000 of such holes. Those holes are located in a single row array. The pitch c/c is 0.4mm.
These holes will be drilled in a die. There will be approx. 30 dies manufactured a year.
I need to drill those holes in brass (CZ121), mild steel (of average characteristic) and 316 stainless steel
I am looking for the most economical options for drilling such holes.
1. My options for brass is micro-milling (least expensive, possible micro hole surface finish problem), EDM hard-tool (probably dearest option, high finish quality),
2. My options for mild and stainless steel - EDM hard-tool.
I also considered micro laser machining, however, I have been informed by a company which provides micro laser machining, that they cannot penetrate a material deeper than 1mm.
I would be very obliged for any suggestions.
Thank you.
- You may not post replies
- You may not edit your posts
Forum Rules
