- 1/4 npt internal thread
Hi, I have a 1/2 npt and 1/4 npt internal threads I have to machine (screw cut) on a fanuc lathe, can't tap as in very hard steel. I have a 08 14 NPT insert and 06 18 NPT for the 1/4 thread. Problem is I know it's a 1/16 taper but don't know the start dia or the thread length or what size to bore the taper. Do have a engineers hand book that's only any good for the tapping drill size for both these threads, any help would be great.
Also I have step gauges and program in metric using a G76 for the thread
Is this what you are looking for?
Have seen this chart yes Thanks
Is the problem in that you do not know how to read the information off of the charts?
Yep found it hard to make sence of the chart, I have the job on the machine and need to crack on in the morning. Was just looking for a quick easy way out to get the figures and complete the job
For 1/4-18 - Starting Diameter is 0.49163.
For 1/2-14 - Starting Diameter is 0.77843.
Does that help?
- You may not post replies
- You may not edit your posts
Forum Rules
