General Material Machining Solutions
Page 1 of 29 123411 ... LastLast
Threads 1 to 20 of 579
Forum: General Material Machining Solutions
Discuss Material Machining Problems and Solutions Here.
  1. Question Q: Deep (~9") Drilling Speeds & Feeds
    Started by thinkless‎, 12-13-2017 02:35 PM
    cutting feed, deep drills, drilling, feeds, speeds
    12-14-2017, 01:21 PM Go to last post
  2. Can Keizen foam be CNC cut with a mill?
    Started by FoxCNC1‎, 12-09-2017 04:56 PM
    bit, cnc, recommend, tittle, tool
    12-09-2017, 04:56 PM Go to last post
  3. Newbie- Mitre fold realy thick board
    Started by tricud‎, 11-25-2017 09:22 AM
    11-25-2017, 09:52 AM Go to last post
  4. Newbie- Advice re Milling Aluminium
    Started by GaryWilliams‎, 11-10-2017 06:43 AM
    11-10-2017, 09:16 AM Go to last post
  5. Just In Cutting fiber cement sheet
    Started by Junaidzia‎, 11-07-2017 02:37 PM
    sheet, cutting, cement, fiber, note
    11-09-2017, 07:23 PM Go to last post
  6. Micro Machining with 0.1mm dia cutter any one?
    Started by Zuedog‎, 10-29-2017 06:33 PM
    10-30-2017, 03:15 PM Go to last post
  7. small hole in thin metal
    Started by parrotcam‎, 10-15-2017 04:04 AM
    brass, diameter, drill, hole, type
    10-15-2017, 10:10 AM Go to last post
  8. Question Need Help!- Breaking Cutters is breaking me
    Started by ChrisWalker‎, 06-25-2017 01:41 AM
    3 Pages
    1 2 3
    aluminum, breaking, cut, largest, part
    10-04-2017, 08:14 AM Go to last post
  9. Need Help!- Machining 316L
    Started by Seferov‎, 09-29-2017 04:28 AM
    316l, finishing, machining, steel, tool
    09-29-2017, 04:28 AM Go to last post
  10. Need Help!- Required aluminum-bronze machining fesibility
    Started by utkhatal‎, 09-08-2017 06:21 AM
    aluminum-bronze, cut, easy, fesibilty, material
    09-08-2017, 04:06 PM Go to last post
  11. Cutting steel vs brass
    Started by Soyland‎, 07-31-2017 03:49 AM
    brass, cnc, cutting, steel, theory
    07-31-2017, 09:29 AM Go to last post
  12. Best Foam for Milling 3D Sculptures
    Started by thinktankgroup‎, 07-20-2017 12:47 PM
    advice, foam, foam cnc, milling, sculptures
    07-20-2017, 12:47 PM Go to last post
  13. Video (VIDEO) Milling aluminum with a 2mm end mill.
    Started by dillonfitz‎, 07-02-2017 11:08 PM
    iphone, tapatalk, mill, aluminum, milling
    07-02-2017, 11:08 PM Go to last post
  14. Question Newbie- source for plastic / aluminum cutting plates?
    Started by emaayan‎, 06-15-2017 03:29 PM
    aluminum, cost, cutting, plates, source
    06-15-2017, 04:35 PM Go to last post
  15. Looking for a bit for phenolic
    Started by Wildkard‎, 05-27-2016 03:03 AM
    bit, edge, holes, parts, top
    06-12-2017, 08:22 PM Go to last post
  16. Need Help!- Table Height deviation = tool marks?
    Started by FoxCNC1‎, 06-07-2017 12:55 AM
    board, cut, height, markings, part
    06-07-2017, 05:39 AM Go to last post
  17. What grade of steel for rack and pinion?
    Started by Eddieb378‎, 05-25-2017 05:50 PM
    05-26-2017, 10:12 AM Go to last post
  18. Newbie- Need Recommendations to cut carbon fiber
    Started by FoxCNC1‎, 04-26-2017 04:44 PM
    05-24-2017, 07:12 PM Go to last post
  19. Need Help!- CNC cutting alum. bracket (2d). - need some feeback please.
    Started by FoxCNC1‎, 03-26-2017 04:04 PM
    05-24-2017, 07:05 PM Go to last post
  20. Need Help!- Issues Cutting Copper
    Started by Teldin‎, 02-03-2017 10:25 PM
    blade, cnc, copper, cutting, pieces
    05-14-2017, 01:31 PM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 6 users browsing this forum. (0 members & 6 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
