I can't get your link to work, is it just me?
I'd hardly call a mirror made from a hard drive free, with the prices of hard drives nowadays
That's right! A friend over at BuildLog.net (Walt) introduced the idea of making emergency replacement mirrors from an old harddrive disk. I took on the task of putting the idea to a test. WOW! It works really well.
I wrote the whole process up and included lots of pictures and some impressive test results. So take a look if you want to make your own CO2 laser mirrors for free!
Check it out here
tim
DIY Laser BLog
- Why do some systems use mirrors to aim the laser instead of mounting to the gantry?
- Need FS Mirrors?? two places to get them 'free'
- help with calibration of mirrors - lenses of 120 W acrylic laser machine
- Cutting 1/32" thick mirrors using a CO2 laser
- Need Help!- Laser Engraver Leaving Streaks when Engraving Mirrors! Any Suggestions?
I just tried the link and it worked fine. I also checked the blog and there have been 22 hits from here this morning, so it must be working for some. If anyone else finds differently, please let us know.
If you could get to the article, you could read that I tell people where to get free HDs as well
Link worked fine for me. You would be a fool to use anything but a free hard drive to make mirrors from. If you cannot find an old free desktop computer case you are not trying.
Matt
The link seems to work fine for me now, it was probably something on my end...
I was attempting to be funny on the hard drive prices thing, I guess my humor just doesn't make much sense to anyone else
Even if you bought a $200 hard drive with 3 platters, if you get 15 mirrors from each, thats 45 mirrors for $200. Humor and sarcasm are often lost in digital translation.
Matt
Thanks allot Tim,
This is great because i needed some new mirrors
cheers
Today i opened a broken Harddisk and going to buy a hole drill
its getting more fun with these cheap mirrors
the price of HD is higher than mirrors in china
yes a new one is, but here if something is broken we usually give it away for free.
yesterday i got 2 harddisks from my neighbour, chinese mirrors are way more expensive then.
I read this a while ago with interest and I wondered if instead of a hole saw, it might be possible to waterjet cut them with a bit more accuracy and less clean up. Covering them with tape would protect them - I know it does add some cost but it just might be easier?
When you used these, did you get similar resulst to your normal mirrors?
You could use a water jet, but don't see the pint of spending the money for it.
Performance has been perfect.
This is awsome! Has anyone tried to cut them out on a mill? you could make them exact size then and use a better bit. Just thinking out loud here.
Necessity is the mother of all invention (unknown)
My club home page www.lhmac.org
Yes, milling them out works.
I just got hold of a used 80w cutter and the mirrors were in pretty bad shape so some googling led me here.
Found an old hard disc and I just cut 6 x 24.5mm diameter discs on a router with a 2mm ball end mill, 10000 rpm, 900mm/min, 0.33mm per pass, total depth 1mm deeper then the thickness of the platter. I stuck masking tape to protect the top and the disc platter was stuck to a sheet of acylic (with the protective film still on) with double sided tape. The cut discs popped off cleanly and have perfect edges. Obviously YMMV but laser is cutting much better now
Jon
Gave this a go today, but cut them on the bandsaw roughly and sanded the edges with the linisher, 3 new mirrors in about 5 minutes once I got the case open. No #9 torx just drilled them out instead. Only wish we had a simple fix for tubes.
