Hi Dave,
Thank you for your advices and I'm sorry about my delayed answer!
My laser machine is Rabbit Laser HX 4060-SE, 60W
I did all of those measurements as you adviced and I found all of those measures quite similar. After that I measured the distance between the rails and I noticed that the measure in the end of the rails was 0,65mm wider than the front of the rails. So my first thought was that I've found the reason (
) and I started to do remounting for those. After mounting I measured it again and now those rails was equal from front to the end. I started to refocus the light way and as you can guess... no change - I couldn't adjust the light way to the middle of the mirror's so that it keeps the position around the table. Now I was quite helpless what to do. After a little moment of thinking I desided to unscrew those prisms from the aluminium holders and check them. I noticed that the prisms was under a lateral force which was twisting the prisms out of the aluminium holder. The reason for this seems to be the adjusting of the linear bearings on the laser beam. This
was the next step I started to check out but I couldn't get it done because
the "mighty forces" commanded me out of my study !
I'll let you know if this was the reason ( as I hope and assume ) after I've
got the permission to continue my research ! As my nickname tell's, I'm not
any expert with the laser machine, so I have to ask about the light way;
If the beam of light doesn't go exactly through the middle of the lense, how
much it will take off the laser power ?
Also, I'm very sorry about my bad English - hope you'll understand !
Best regards from Finland
- Hannu
