Need Help! hx40b
Results 1 to 8 of 8
Thread: hx40b
    Mar 2008
    south africa
    Default hx40b
    hi guys
    im new here and hoping you guys can help me with this machine thats driving me nuts!!!
    well i bought it to make rubber stamps but its been 3 months and nothing
    it comes with newlydraw or something like that
    so i import my artwork which i did in corel draw into the program
    select it and choose scan mode and then click engrave and it gives me a data error after 1 second then goes to another window where u get more options
    so i click start and it does it but doent even cut through a 3mm thich piece of rubber
    has anyone made a rubber stamp on this machine and if so can u please help me with the settings?cause im now losing hair!i swear!
    Sep 2007
    Default Try to help
    Where did you buy you machine ? Frank ?
    What are the power and speed settings you are using ?
    Are your mirrors aligned correctly ?
    Is the machine on automatic power control or manual ?
    Let me know and I will help you as much as I can. Jim
    Rabbit Laser HX6090SC
    Mar 2008
    south africa
    i bought it from a lady whos name is green su...lol
    power set to 30 percent\speed 250
    scan mode
    how do i know if its auto power or manual?
    still getting data errors everytime i press the engrave button
    Sep 2007
    Default ok
    Try this test,Open up newlydraw. Type your name, using the text button in the tool bar at the top. You can leave it to cut, the letters are red. If you want to engrave, switch to engrave mode, letters are black, top left in tool bar. At the top left of the tool bar are X, Y measurements. These are the locations on the cutting table. Click on the engrave tab in the tool bar. When that window comes up, set your power and speed. Click the engrave tab. Let me know what it does.
    Aug 2006
    france
    Hello
    I have a hx40a and newlydraw to make stamps and it works very well.
    you say : "power set to 30 percent\speed 250"
    So I think you didn't selected the good laser in the "engrave" panel. Didn't you selected the "rabbit 30/40" insted of "rabbit40"? (I'm not sure of the exat names because i'm not at work)
    my setup for stamps :
    - first pass:
    scan speed : 10
    laser setup to 10 mA
    -second pass :
    I add a stroke of 1mm everywere
    scan speed : 10
    laser : 10 mA
    excuse for my english, I'm french
    Nov 2007
    I have been struggling with newlydraw and my hx3040 making rubber stamps.
    How do you set the steps for letter support (shoulders) in newlydraw?
    below is an illustration from another program:
  7. #7
    Apr 2010
    China
    Lightbulb
    Quote Originally Posted by nazirabd View Post
    scan mode
    hi,
    from your words, you set the power 30 percent in the Newlydraw,
    it is okay for engraving, but the speed, it is better you can have a try with 100-125
    about the auto power or manuel, it is controled by a switch at the right side wall of the working box whenyou facing the machine.
    better you can contact miss green and she or their tech should be able to help you with the problem.
    Good luck.
  8. #8
    Apr 2010
    China
    Lightbulb newlydraw and hx3040 making rubber stamps
    Quote Originally Posted by CanAm View Post
    Hi CanAm,
    For the hx3040 making rubber stamps,
    how do you mean to set the steps for the letter support in newlydraw ?
    generally, it is easy and automatically, no need any extra operation settings.
    so you are facing problem in your working with the Newlydraw,
    have a look at the Rabbit company web, there is a vedio for showing you how to start working with a mini laser machine.
    http://www.rabbitlaser.com/products/40avideo.htm
    it is easy. Good luck.
hx40b
hx40b
