Need Help! Problem with engraving
Results 1 to 6 of 6
Thread: Problem with engraving
    Feb 2018
    Lithuania
    Default Problem with engraving
    Hi Guys,
    i have laser JQ1390 and i wil try to explain my problem and nobody can find what happen
    As you can see on the picture, about every 6-8 cm laser engraves bigger letters,it looks like going bigger and bigger and then looks like power going down and engraves nice and smooth ... Light path ok, working table ok, so no idea what going on..
    Thank you guys and waiting yours replyas...
    Feb 2018
    Indonesia
    Default Re: Problem with engraving
    have you tried resetting the machine?
    Feb 2018
    Lithuania
    I reinstall software, but did help
    Aug 2016
    Quote Originally Posted by Urte View Post
    Maybe it's just me, but I can't see a picture?
    Feb 2018
    Lithuania
    Problem with engraving-img_20180212_120104-jpg
    Sorry
    Attached Thumbnails Attached Thumbnails Problem with engraving-img_20180212_120104-jpg
    Aug 2016
    So when you say light path ok, and working table ok, what did you do to make sure they were both ok? Clean mirrors and lens, check beam alignment? And what about table height, did you check the distance from the nozzle to the work surface at a few different points? Has the machine been altered recently in any way?
    If everything mechanical and optical is fine in the path, then that narrows down the problem to perhaps the tube itself. If the beam is changing over time, perhaps you have a water cooling problem such as low flow, temperature out of range etc.... Or maybe the tube or power supply is broken.
