After attemping to purchase an Inventables X-carve (all out of stock), then a digirout 200 series (materials not available), I ended up with this unit.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
There are no instructions provided with the machine, but some searching and I found this videos for configuration:
I followed this exactly, and Mach 3 shows the x,y,z moving with the arrows, pg up, pg dn keys, but no movement from the table.
All cables are connected properly. I took the top off the blue controller box and can see the lights on the board switching on and off when using the keyboard, still no movement from motors.
The motors included are:
STEPPER MOTOR
JK57HS76-4204VB-01AF
Can anyone help me out with what might be wrong, without saying to buy a better controller?
I'm not completely against it, but this should work as delivered.
Thank you!
