LaserDRW How to Calibrate Wrong Cut Size?
Results 1 to 3 of 3
Thread: LaserDRW How to Calibrate Wrong Cut Size?
    Oct 2016
    Default LaserDRW How to Calibrate Wrong Cut Size?
    Hey Guys,
    I just engraved a 15cm long line and the real length is 13.8cm.
    I read how to fix this but none of the example was for LaserDRW which is (I think) the only program (which I prefer not to change) that works with my machine.
    Any ideas how to fix this?
    Roy
    Mar 2016
    United Kingdom
    Default Re: LaserDRW How to Calibrate Wrong Cut Size?
    HI
    DRW always imports the wrong size just select the object an set the size in the right hand size bo
    Attached Thumbnails Attached Thumbnails LaserDRW How to Calibrate Wrong Cut Size?-untitled-jpg
    Oct 2016
    I just realized the problem, it did it only on straight lines and not on squares and turns out that the width of a straight line there is not really clear...
    Anyway I don't use lines only simple squares...
