hi
its because your controller is not compatible with RD works
now I have not tried it but there is a free software out there called K40 Whisperer which works with most of your type of controller
HTH
Dave
Edit: Fixed it!
but it only works with an annoying software called LaserDRW.
I tried with the nice software called RDWorks V8 and it doesn't communicate...
Why is that?
- Need Help!- My chinese laser cutter won't work at all, software doesn't see the cutter
- Need Help!- DDCSV chinese stand alone controller doesn't open gcode
- Need Help!- Chinese laser 100W doesn't fire after replacing a Leetro controller
- Newbie- CO2 Laser tube 60 W doesn't cut
- Newbie- Laser doesn't start???
hi
HTH
Dave
You could try Lightburn
Lightburn is awesome, but I don't think it supports LaserDRW-compatible controllers yet.
https://github.com/LightBurnSoftware...ster/PreReq.md
Is it possible that there is only one software for my laser cutter? (LaserDRW)
yes it is possible but as said earlier try K40 whisperer
I didn't understand the K40 Whisperer, it seems like a software that is only for communicating with the laser machine and not for designing anything, so it makes every cut a two step process
