Until very recently, I was using EZCad with my laser cutter on my Windows 10 OS. However, after the most recent Windows Update, I am no longer able to boot up my EZCad software. It will crash and give an MFC application error.
Has anyone else experienced this? If so, does anyone have any ideas for a workaround?
I've done some research online and have tried to run the program as an admin and have tried to run it in a clean boot, but nothing is working. Looking forward to your responses.
hi I have had problem with similar software you need to revert back to a previous build
To go back to an earlier build of Windows 10, open Start Menu > Settings > Update & Security > Recovery. Here you will see Go back to an earlierbuild section, with a Get started button. Click on it. The process to revert your Windows 10 back will commence.
HTH
Dave
Could you please share with me the EzCad which works for Windows 10.
I have one which works only on Windows 7 Professional. Microsoft no longer provides support for Windows 7.
You could write to me on davidburkus60@gmail.com
