Need Help! Power questions for Redsail X700
Results 1 to 2 of 2
Thread: Power questions for Redsail X700
    Jan 2010
    Default Power questions for Redsail X700
    I just received my Redsail X700 today and have some questions about input power.
    The machine power data plate is marked 220V 50 Hz 10 A. That's 2200 watts as I see it. The machine came with a 110V to 220V converter rated at 1000 watts. That doesn't seem to be enough to run the machine. Has anyone else had this problem.
    My second choice would be to use the 220 V 60 Hz power in the shop and connect it directly. Most of the components run off the low voltage power supply except the cooling and exhaust fans but I don't know if the 60Hz will be an issue with the power supply.
    I'd like a second opinion before I hook up any power.
    Any help will be appreciated.
    Tom
    Registered john-100's Avatar
    Mar 2007
    uk
    Default Re: Power questions for Redsail X700
    assuming the machine has switch mode power supplies that have a large switch on surge current , possibly 4 times the running current
    the over all power requirement may only be 1/4 of your expected 2.2 Kw
    another other factor that affects your calculation ,
    is the current take in phase with the input voltage ? not all power supplies have power factor correction
    John
