Need Help! Issues with MDF cutting - Random burning on the back of material - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 16 of 16
Thread: Issues with MDF cutting - Random burning on the back of material
  1. #13
    Aug 2016
    Default Re: Issues with MDF cutting - Random burning on the back of material
    How did you go rjavier? Did wetting the back make a noticeable difference for those longer 3h jobs? What about that bigger compressor you were going to try?
  2. #14
    Aug 2014
    Quote Originally Posted by Blackened View Post
    Hey! We are still waiting on a friend to lend us a more powerful compressor. For now what is working very well is to run the cutting job twice, at twice the speed. Same total amount of time, and actually the cuts are better looking.
    But I am still sure that the MDF we use (low density) has a lot to do with it. We use low density bc its the only one our laser is able to cut, high density its a no-go. This is right now my recommendation.
    We didn't do wetting for the following ones because in longer jobs, it would almost dry up. I still think the best approach is good air and two faster runs.
  3. #15
    Aug 2016
    Good to know you found a workable solution. I figured it would dry out for longer jobs yeah. I wonder if there's an additive you could use that's both non-flammable and wouldn't ruin the MDF, that would act as a more persistent wetting agent?
  4. #16
    Aug 2014
    Maybe, but I don't think its a big issue for most. Cutting 15mm MDF with a 150W laser is barely done by anyone. If you ask most sellers they will definitely not assure you you can do it, at most 10mm. And bigger businesses that do this, they just have a big ass 300-400W laser, obviously at a massively bigger price.
