Has anyone that uses the Trocen AWC708C Lite found an easy to understand English manual? I'm referring to a manual simple to understand that explains all the settings in simple terms. Not a Chinese English translated manual.
I have manuals from Trocen and Sinjoe, but both are Chinese English, which is difficult to understand.
A few problems i'd like to correct.
1. Y motor stalling
2. Slow down homing at power up speeds
3. Change homing sensor state to normally closed (NC)
4. Set home or origin (0,0) to front left of the X-Y Stage.
Y motor stalling like it won’t run at all? Not wired correctly?
Or looses steps when trying to rapidly move the X axis? Bigger motor or settings on the drive.
In the software You could have accelerations too high or step settings too large for the pulse settings on the drive.
It might be best to work everything out with the belts disconnected first
Rest of that stuff can be found if you study the settings carefully.
Thanks Dean. Y motor issues were a current setting on the driver. I dropped them to 2.7A from 3A and are working fine now.
I got the Light Object manual for the LO-X7 DSP which is a AWC708C and made some headway. Reading from all three manuals helped, but not much. Also found loads of info at the Buildlog 2.X DIY Laser forum.
I was not able to find any info on the homing switch state. It seems I can only enable/disable the setting, and switches need to be wired as NO.
Home at (0,0) was weird. I had to set Datum in Manufacturer Parameters. Now to figure out how to do motor tuning.
