Look at your tube to get the model/series number. Then go to the RECI website and you will be able to look up the specifications for your tube.
I have a laser engraver on order with a 100 Watt RICI tube and would like to know what the optimum operating current would be. I understand that over driving the tine will cause early failure but what is the optimum current value.
Thanks,
Tom
"80 Watt” 700mm x 500mm Ke Hui KH-750 Laser (Similar to the Red Sail)
I run mine at a maximum of 24ma. Yours might not be the same though.
