Newbie Will K40 laser cutting machine do the job?
Results 1 to 4 of 4
Thread: Will K40 laser cutting machine do the job?
    Nov 2017
    India
    Question Will K40 laser cutting machine do the job?
    i want to cut a printed 2mm PVC sheet, i want cutouts of the printed area, so would like to know if it can be done using a K40 laser cutter machine
    the below link is an example just for the idea of the print
    https://ae01.alicdn.com/kf/HTB1jlVVRXXXXXaMapXXq6xXFXXXd/-font-b-Car-b-font-Auto-Fashion-Pendant-Interior-illest-JDM-Hellaflush-Rear-View-font.jpg
    i'm looking for a cost effective solution, what do you guys think about it?
    Mar 2013
    Slovakia
    Default Re: Will K40 laser cutting machine do the job?
    PVC is one of the materials, you should never cut on a laser cutter !
    ... during the cuting process (or burning) chlorine is released from the PVC (PVC = Poly Vinil Chloride) and the chloride will:
    - damage your equipment
    - hurt/poison the operator
    So again:
    NEVER EVER CUT PVC ON A LASER CUTTER !
    Nov 2017
    India
    Quote Originally Posted by DRACO.SK View Post
    So again:
    I didn't know the risk/harm of cutting PVC by laser, thanks for the quick reply. Now I need to find some other material or cutting method.
    Sent from my ONEPLUS A3003 using Tapatalk
    Oct 2015
    If its one off work i would suggest a cnc router, but if you want to make the same thing in production u should get a punch press
    Sent from my LGLS755 using Tapatalk
