No answers !!
Hi friends,
i got a new RDC6332g laser control system. when i switch it on i got the boot screen below & never go till i press ' RESET ' button!!
when i connect the machine to the laptop & trying to read vendor settings i got ' No devices connected '
when i try to change the parameters locally from the controller using the master key ' 666888 ' i got the same message ' No devices connected '
i can't move the axis , fire the beam, read flash disk ... etc
anyone know how to fix it please?!!
- external devices connected to a CNC machine
- What is the difference between a Ruida RDC6332G and RDC6442G controller?
- Granite Devices
- Need Help!- forget RDC6332G machine perimeter reset password
- Bridgeport Series 2 Interact 4 parts and Granite Devices servo driver boards. Incl. Heidenhain TNC 155, Bosch servo drivers, Heidenhain handwheel encoder, Granite Devices VSD-XE - No Longer Available
No answers !!
Most laser users on this forum use the newer 6442G or 6442S controller so there probably just aren't that many people here with experience using that controller.
"80 Watt” 700mm x 500mm Ke Hui KH-750 Laser (Similar to the Red Sail)
Any news to this problem?
I think the problem is with the drivers as the one board is from a customer, one board is new and one board is out of a cupboard.
I have tried RDWorksV8.01.18 and MetalCutSetUpV1.00.17 with no luck.
I have also paused my AVG internet security to see if this will make any difference.
I would really appreciate any help.
