Need Help! Wrong RDWorksV8 scan settings
Results 1 to 3 of 3
Thread: Wrong RDWorksV8 scan settings
    Jun 2017
    Lithuania
    Default Wrong RDWorksV8 scan settings
    Hello, please somebody send me information what should be settings of software program RDWorksV8 (Rdcam) for engraving plywood? Where are they set? It looks like something is wrong with settings or software because alignment and optics are OK. The details are too deeply engraved and thin lines are missed at all. Thank You in advance!
    DiverBob if you are reading this post,
    I am using birch or poplar plywood. I have uploaded .rld file as you requested. Please help me with settings. Thanks in advance for everyone who is trying to help me!
    Attached Thumbnails Attached Thumbnails Wrong RDWorksV8 scan settings-20171113_124048-jpg   Wrong RDWorksV8 scan settings-20171113_124103-jpg   Wrong RDWorksV8 scan settings-20171113_124128-jpg
    Jan 2017
    Default Re: Wrong RDWorksV8 scan settings
    Try to run it at speed 50 and then adjust power for cut depth. Make sure you are using black and white jpg.
    Jun 2017
    Lithuania
    Hello all, my CO2 laser started engrave badly. If I'm decreasing the speed and/or increasing power it engraves better, but still not as I wish or as it was some time before. It seems my laser is passing thin vertical objects when engraving. Alignment is ok. Tube is OK. PSU is new.
    What can influence this: software problem, bad optics problem, free straps problem, etc?
    The problem is very similar as shown in this video
    Please help!
