Need Help! CO2 Laser cutter/angraver
Results 1 to 2 of 2
Thread: CO2 Laser cutter/angraver
    Jun 2017
    Lithuania
    Default CO2 Laser cutter/angraver
    Hello good people! I have Chinese CO2 lase cutter/engraving machine. Some time ago it started to engrave badly. I am not sure I am right but I noticed strap loose from both side of moving head. See pictures attached. Please look at yours and compare to mine. Can this be a reason of terribly engraving? Or I should check something else. If this is strap loose how to tighten them? Could somebody send me link of video? Than You!
    Attached Thumbnails Attached Thumbnails CO2 Laser cutter/angraver-20171113_123310-jpg   CO2 Laser cutter/angraver-20171113_123325-jpg   CO2 Laser cutter/angraver-20171113_123411-jpg
    Jan 2017
    Default Re: CO2 Laser cutter/angraver
    Quote Originally Posted by Lietuva View Post
    You need to tighten the belt. Should be a screw on the right side of rail. The slack in the belt will not allow the head to stop and start correctly or the wrong place.
