Problem Dual Laser 110v plug melting
Results 1 to 4 of 4
Thread: Dual Laser 110v plug melting
    Jul 2016
    Default Dual Laser 110v plug melting
    I have a Gweike laser and the power plug housing has literally melted twice in the last week (see picture). Any ideas?
    Attached Thumbnails Attached Thumbnails Dual Laser 110v plug melting-img_4071-jpg
    Nov 2017
    Egypt
    Default Re: Dual Laser 110v plug melting
    if the wires are good you need to get stronger plug..
    that happens when the machine consume a current higher than what the plug can carry ..
    more current more heat
    Registered john-100's Avatar
    Mar 2007
    uk
    do you know what power the Laser cutter takes ?
    does it have any mains outlets to power external devices like a water chiller and or extractor fan ??
    its possible the combination of these is overloading the 10A mains inlet
    John
    PS
    if your laser cutter / engraver has outlets like this :
    Dual Laser 110v plug melting-mains-outlets-jpg
    with a 110V mains supply the total load must be limited to 1100W
    if the laser cutter takes 300W , the total power that can be taken from the mains outlets
    will be 800W (you may have to reduce this if the chiller and blower take a large start up current)
    Aug 2016
    I will 3rd what the others have said. Don't power anything using the power outlets on the back of the machine itself.
    "80 Watt” 700mm x 500mm Ke Hui KH-750 Laser (Similar to the Red Sail)
