I always want to support enthusiasts and hobbyists ...
Results 1 to 7 of 7
Thread: I always want to support enthusiasts and hobbyists ...
    Registered MyRobots's Avatar
    Jul 2016
    Naples, FL
    Exclamation I always want to support enthusiasts and hobbyists ...
    I always want to support enthusiasts and hobbyists and help to answer questions about lasers, engraving machines, so if you have any questions about lasers or you want to share with your experience while working with our or someone's else lasers, you are welcome to do this:
    Feedback from our customers - EnduranceLasers
    Share your story here!
    If you have any issues you need to solve, do not hesitate to ask here! we will be happy to help!
    Registered theviltherapist's Avatar
    Nov 2017
    Default Re: I always want to support enthusiasts and hobbyists ...
    Hi i need help with 50watt chinese laser machine black n white.
    Whenever ictry to target an object laser tube fires very weak it barely marks wood and just making a tiny whole if i press test button on a paper even with 80 amper power last night i was working just fine and all the sudden it stops working when i tried to do the job again it started point very week laser beam on the target please help if anyone knows if it is tube problem or power supply fault, I bought it 4 days ago brand new.
    》FAN ON POWER SUPPLY IS OK
    》LIGHT ON POWER SUPPLY OK
    》when i press test button i see very dim laser beam inside laser tube.
    I can share photos if required, Cheers
    Sent from my SM-A800F using Tapatalk
    Jan 2017
    Quote Originally Posted by theviltherapist View Post
    Your mirrors might not be aligned or dirty. Put a small peace of plywood in front of the tube and press the fire button. Next test after the first mirror and so on. Use the included orange plastic gauge to set the correct distance.
    Nov 2017
    Quote Originally Posted by engraving_hub View Post
    Thanks for your reply yes i have tested they way u described one thing i would like to mention here whenever i press test button i cant see pink beam its very dim and weak beam insode laser tube also tried power 20 to 80 but no change what do u think laser tube has broken? Should i change it ? Or theres a solution for that?
    Jan 2017
    The tube should be a light pink. Test at 99%.
    Aug 2016
    My guess is that you "over drove" your tube/power supply and killed the tube. Very common with these machines if you ran it at 65% power or more, due to the fact the tube's rating is not truthful. Fortunately for you, you just received your machine so it will be covered under warranty or you just do a chargeback on your credit card.
    "80 Watt” 700mm x 500mm Ke Hui KH-750 Laser (Similar to the Red Sail)
  7. #7
    Registered abyss's Avatar
    Oct 2015
    United Kingdom
    MyRobots, is this genuine?
    Polish @ Éire
