When you changed the frame, what parts of the motion system did you alter? IE: belt drive would require new/longer belt etc... You didn't change the drive pulleys at all?
So I recently upgraded my engraver to a larger work area and am now having an annoying issue. All of my prints are coming out about 28% smaller then what it DXF is scaled too. For example I tried to engrave on a 9.5 inch piece of wood that should have been pretty much covered but the design came out at about 6 inches only. This is a consistent issue with the only change to the system being the frame. All of the electronics are the same as before. I figure it's a software issue somewhere since what work it does do is as it should be, but with a 28% size reduction.
No worries Glad you figured it out
