Need Help! engraving on plastic project boxes
Results 1 to 13 of 13
Thread: engraving on plastic project boxes
    Feb 2006
    Default engraving on plastic project boxes
    I have plastic project boxes and wondering if I can use a laser to put text on box?
    Registered Jerrywu's Avatar
    Feb 2017
    China
    Default Re: engraving on plastic project boxes
    Yes, the laser can do it
    We are a company focus on CNC inspection.
    www.cncinspector.com E-mail: info@cncinspector.com
    Feb 2006
    Quote Originally Posted by Jerrywu View Post
    What power laser would I need to do this?
    Jan 2008
    What kind of plastic is it. If it is has PVC in it then the answer is no
    Feb 2006
    I think it is ABS. Is there a way to test?
    Jan 2008
    Quote Originally Posted by fixtureman1 View Post
    Yes what you do is take a piece of copper wire and heat it then use that to get a small glob on it. Hold that in a flame and if it burns green it has pvc in it.
  7. #7
    Feb 2006
    Factory said it is ABS. So I just want to add some writing on box. What kind of laser and power do I need. And how permanent will this writing be.
  8. #8
    Jan 2008
    a good 40 watt would do it but not one of those $400 ebay units they are junk. I bought mine from Automation Technologies Rabbit laser is a very good company if you talk to either one they should be able to point you in the right direction. I went to both with a sample of what I cut and they did a demo for me.
  9. #9
    Mar 2008
    Vent to the outside. ABS produces some very nasty vapors when burned.
  10. #10
    Aug 2017
    Quote Originally Posted by Ed Williams View Post
    Check with laser manufacturer as some plastics can create a gas while being marked, that will really damage your electronics and wires. Past reports have noted..completely ruined.
    Sent from my SM-G900V using Tapatalk
  11. #11
    Dec 2006
    ABS will not discolor when marked or laser engraved. In other words, you can see the texture and shadows after laser processing. The engrave quality is considered low because it can be difficult to see. For example, a bar code reader fails on an ABS that is bar coded. However, if your intent is not for looks but for information, such as a required part number, then laser processing can suffice.
  12. #12
    Gold Member MichaelHenry's Avatar
    Jun 2006
    Chicago suburbs
    If legibility is important, maybe a good approach would be to apply transfer tape to the box, laser the marking on the box (which should burn through the masking as well as engrave the box, apply some sort of paint to the engraved letters, and remove the masking after the pint is dry.
  13. #13
    Feb 2006
    Sounds like I should just silk screen.
