Need Help! Not engraving small objects
Results 1 to 1 of 1
Thread: Not engraving small objects
    Jun 2017
    Lithuania
    Default Not engraving small objects
    Hello,
    I am using Chinese Laser cutting/engraving machine for almost half a year. Usually I'm working with plywood 4 mm and using AutoCAD vector models. Some time ago it started engrave very badly. It looks like there is a problem when engraving objects, because engraving is always shifted to the right but bigger problem appears when engraving small, thin line objects or text. I have to mention that alignment is ok and everything is fine with cutting. Please help to indicate where is the problem - settings/parameters, firmware/software, where else?
    Attached Thumbnails Attached Thumbnails Not engraving small objects-forumui-jpg
