Thunderlaser Nova 63 and big item
Results 1 to 1 of 1
Thread: Thunderlaser Nova 63 and big item
    Mar 2015
    Default Thunderlaser Nova 63 and big item
    I have a plywood item with 1200*1200 size , and I want to cut it using my Nova 63 with 1600*1000 work table.
    So as you see, the width of work table smaller than the item, but I can put the item to the table without front panels with honey table.
    I am already cutting 1500*1500 items without front panels using broaching openings, but only for 1600*1000 work table.
    May be there is a procedure for broaching of fabric roll that I can use for my case?
    Is there a procedure in order to cut it right ? Perhaps using laser red dot and dot scan of first point?
    Should I сut the drawing in two pieces with this procedure?
    Thanks in advance.
