Just seal it. Whats the problem? Check water tubes and seal.
So purchased new CO2 laser on ebay, started it up and noticed a bad leak coming from inside back of machine. Above is a link to youtube video of the leak and where its coming from. i was told to put some silicone where the leak was coming from and after doing that it started leaking from other spot on that sensor/switch.. dont know what to do now and the customer service is horrible..any input would be greatly appreciated..
CNC lasers, constructions, service
It should'nt be leaking like that, I put silicone all over, especially where it was leaking from lets see if that works. Did you ever have this issue?
Silicone is not a solution. Find WHAT is leaking and seal or exchange if necessary.
1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
You're gonna want to make sure everything is dry before sealing with silicone. Let it fully cure. You can also get better tubing from Mcmaster or try some better silicone.
KL-4530 CNC, KL-6060, 5 3D printers, CNC Fusion Converted LMS Milling Machine, 60w Laser Cutter
