Mercury 3 Error - "Communications Buffer is full"
Results 1 to 3 of 3
Thread: Mercury 3 Error - "Communications Buffer is full"
    Sep 2017
    Netherlands
    Default Mercury 3 Error - "Communications Buffer is full"
    Hi All,
    I'm a Newbie to the forum...looking for help with a Mercury 3.
    Ive just moved into a new job with one of these machines. Never used one before but its been working fine until yesterday I got this error which I can't resolve.
    Trying to cut & etch 3mm acrylic from files in 2D Design but its stalling on sending the file (never sends) and the Laser display says that the "Communications buffer is full".
    I can't find anything in the manual about it at all, nor anything online. Any suggestions welcome.
    Rick.
    Sep 2005
    Default Re: Mercury 3 Error - "Communications Buffer is full"
    Quote Originally Posted by Rharman View Post
    Hi All,
    Rick.
    Who makes the machine? Is it Chinese or European, perhaps US, if so contact the Mfg and see what they say. Could be you need to delete the files in machine memory.
    Found in a 30 second google Search > Mercury III_Elite_Products GCC Laser Cutters, Laser Cutting, Laser Engravers, Laser Engraving, Vinyl Cutters, Cutting Plotters, UV Flatbed Printers
    Master Electrician - Retired.
    Apr 2017
    I would guess your file is too big. My laser does the relatively the same thing if I have too many curves or details in a file (it was built in the 80s). Try sending a smaller part of the program to see if that works.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
