I usually find on wood, engraving better with air off and cutting with air on. Lots of flames otherwise.
Here is an odd problem, I am running a 100 Watt Laser with around 108 lpm of air assist. Tonight I forgot to turn the air on and while working next to the laser wondered why I couldn't see through the Acrylic Lid, Opened the Lid to be greeted with a huge cloud of smoke, odd thing was the engrave lines ( P=25 S=100 ) were perfectly clean then as soon as I'd turned the air assist on the lines were like I usually see them, slightly burnt around the lines, what surprised me was the lines with the air OFF were perfectly clean. I would have thought the buildup of smoke would have produced a far worse line then it did. Does this sound normal?
Air assist pushes the super heated vapors from the just-lasered wood back down on to the surface. If you don't have air assist blowing full force but do have good airflow from your exhaust evacuation system, that usually evacuates or dissipates the vapors before they settle down on the wood. I put one of those quick connect in-line air flow valves like Russ showed in his videos. It allows me to turn the airflow down very low to the point there is enough flow to protect the lens but not enough to push the vapors back down on to the wood.
"80 Watt” 700mm x 500mm Ke Hui KH-750 Laser (Similar to the Red Sail)
So is this a homemade machine or commercial? Wondering why your exhaust system did not take out the smoke.
1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
Russ' Ultimate air assist system is the [ultimate] answer. When engraving air assist is turned to the minimum and when cutting you get max flow [using a Ruida controller it is set in the layer parameters].
4x4 shopbot with chicom water cooled spindle
3x4 130watt chinese laser
