awc608 controller issues
Results 1 to 4 of 4
Thread: awc608 controller issues
    Aug 2017
    Default awc608 controller issues
    I have a laser with a aw608 controller. I am having an issue where every time I go to start the file it moves to the origin and then stops. it will not run the file i have tried everything and still no success. Can anyone help me?
    Sep 2005
    Default Re: awc608 controller issues
    Quote Originally Posted by jdoody View Post
    No motion or no laser firing? Has it ever worked or is it just starting to have issues?
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
    Aug 2017
    The laser fires but that's it it won't run the file. It just started today. When I press start it will move to the origin then freeze.
    Sep 2005
    Do you have door switches and a water flow safety switch check those. Make sure your pump is running and all the doors are closed. If those switches are not closed usually it will not fire the laser either. Any error messages on the LCD screen?
