It might burn the anodizing off aluminum with a long time span but for steel not sure about cast iron you need a Galvo Fiber laser of at least 20 Watts. Around $5000 USD.
Hi
I am a newbie here.
I need to mark logos on metals like iron, cast iron and aluminum alloy.
I am considering to buy 10W or 15W laser module as shown here
https://www.aliexpress.com/item/15W-...02.4.76.rRqSHw
I just want to be sure if it would do the job?
Is the cooling from the fan would be enough or I might need some extra arrangements?
Thanks.
1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
Hello. MORN® fiber laser marking machine is suitable for you. It's Affordable and Durable. Please check this listing page, you will meeting your machine.
http://www.morntech.com/laser-markin...g-machine.html
