Originally Posted by
Pitre
Dear All,
We recently bought one 2nd hand AMADA FO 3015 ( Fanuc 160i L ) .....Installed the machine and powered up. Got the Laser power 3600+ ( mirror cleaning required though).
Machine is equipped with HS-98 ( Amada HS-2000 board ) ......Z-axis calibration ( 8010 ) went through successfully.....in TRACE ON & TRACE OFF mode.
When actually...cutting starts ....the head does not detect the material ( SPC2.0) ......and roughly starts cutting 14-15 mm above the material.....sometimes head goes....in Z+ direction....and goes pass Z+ OT switch....giving alarm.
Cutting conditions are set correctly 1) Mtl = SPC ...2) Thk = 2.0 .....3) Head = 2 ......4) Nozzle Gap = 1.5 .......but still it starts cutting 14-15 mm above the material.
even we changed the material....3mm / 10 mm or so......but still the result is same......
Anyone has any solution or advise for this issue....or the calibration procedure for HS-2000 .......or any idea what is causing this.....or whats wrong ....
Please share your views, ideas, chk. points etc.
thanks.
