Need Help! 100w laser cutting intermittently!!
Results 1 to 3 of 3
Thread: 100w laser cutting intermittently!!
    Jul 2017
    Default 100w laser cutting intermittently!!
    Hi again all, so last night i began to cut a few things and straight away i noticed my laser would not fire when supposed to.
    The head is moving correctly for the cut but no pulse from the laser.
    Example: when cutting a circle the head starts at the top centre and moves around but it only started to cut about 1/4 of its way round.
    Cooling is all ok and flow sensor is functioning.
    Im using a universal laser with 100w reci tube and sinjoe awc608c plus controller.
    Can anyone possibly help me out ???
    Dec 2016
    China
    Default Re: 100w laser cutting intermittently!!
    What software are you using?
    From what I see, it should be something wrong with the pulse.
    Try to reset the parameter and see if it will work.
    Best of luck
    Achilles
    www.gurulaser.com
    Nov 2010
    Poland
    Universal Laser with Reci and sinjoe awc608c ???
    Can`t be truth.
    CNC lasers, constructions, service
