208v 380v 400v 415v 440v 600v is a industry standard this covers most of the worlds main power supply's for 3Ph
On just 2 legs they may be as confused as you are, Green colored wire should never be used as a Power wire, ( code violation ) If you meter across the 2 Terminals they will be 220v/240v single Phase supply
So what is on the motor label is it 220v of 440v
In the USA or all of NA you have 120v / 240v supply single phase supply not 220v
Make sure you have a Ground wire also so you need to have 3 wires connected to the motor 2 Hot and Ground it looks like the motor is a standard 220v Cap start single phase motor
