Blow out the collected dirt and clean the fan blades also. Make sure all the fans are running and in the right direction.
hello, after looking around on the forum i found great info and help, but the solution of my/our problem was not among the info problem is as follows:
15minutes after cutting the machine stops and gives error code 170 and 163. even after just turning the machine on and letting is stand idle it generates the same error. after looking through the manual (german) we can conclude that there probably is something overheating. freely translated the error codes should mean something like:
overheating temp t1 tube end
and
overheating air TB1 transistor driver
in the electrical drawings we could not find tb1 or t1 so we are at a loss here. at the moment we are partly cleaning and testing again to check what seems t be the culprit.
any thoughts?
any help is welcome
regards
jeroen
- missing tech tables for a 3kw Trumpf 3030
- Need Help!- Trumpf 3030 Bad Y-Axis Servo?
- Newbie- Trumpf 3030
- Need Help!- Trumpf Laser 3030 unloading problem
- Need Help!- Trumpf 3030 Reference Autolas error!!! HELP!!
1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
