The rectangles should have been aligned, but the laser changes direction too early.
Here it started to cut downwards earlier by 5 mm. On an acrylic cutting before that the error was more than 1 cm.
Is this an RD Works software problem?
Or does it have to do with using the circular engraver before and changing the vendor settings? (I wrote back the original parameters. Also, I cut some more pieces after that which were fine).
