Hmm, I can cut 6 mm with my 40 watt machine, slowly and with almost full power but it gets it done. The glue in the plywood is the issue on how It cuts. Sometimes it varies a bit, sometimes depending on the glue it can not be cut without a lot more power. Try on some just solid wood about that same thickness and see what happens.
