Hi, I am new to this whole engraving/cutting. I have 2 units. Both GoldenSign units a GS9060 and a GS9060S using the following controllers respectively, the AWC608C and AWC708C Lite. The GS9060 with the AWC608C controller is engraving a double image. The second image is only about 0.5mm out but this is obviously a huge issue when it comes to engraving. Cutting seams ok. If i request a square 115mmx115mm then that is what I get. Only issue on the engraving side.
Can anyone recommend a fix, please? I am using the LaserCad software.
