Trouble with Ruida 6442G and drivers Leadshine DM556
Hi all! I build my laser cutting machine and have next config: Controller: Ruida 6442G Drivers: originally Leadshine DM556 Everything works well, but there is one big problem. I'll try to describe it in steps:
Laser head in Origin. Click Pulse and see dot. All ok.
I start to cut a large file with a lot of small details (file included).
After cutting head back to Origin. Again click Pulse and see that the point has moved 3 mm down and 5 mm left.
I have another controller, AWC 708С Lite. I connect it and everything works fine. On the forums I read that I need to change the parameter Active Edge. I changed the parameter from "Rising" to "Falling", but the problem remained. Tell me how can I fix the problem? Thank you!
