Problem Bad Laser cutting on Aluminum 3KW
Results 1 to 7 of 7
Thread: Bad Laser cutting on Aluminum 3KW
    Jun 2017
    Default Bad Laser cutting on Aluminum 3KW
    i have a Mitsubishi Laser Machine 3KW, i try to cut aluminum with air and my dryer does nor work properly so i see water into my nozzle
    after that i clean and purge the lines, now i use oxygen to can cut aluminum 0.050" thickness the machine start good but a few inches of cutting
    the cut was horrible and later the machine stop the cutting.
    Feb 2009
    Default Re: Bad Laser cutting on Aluminum 3KW
    Thought you were supposed to use nitrogen on aluminum?
    Sent from my SM-T813 using Tapatalk
    Jun 2017
    I was use oxygen in the past and I was cut the aluminum, actually that option comes in me machine with oxygen or nitrogen.
    Quote Originally Posted by underthetire View Post
    Feb 2009
    Each machine is different, but I'd look at the optics then. The water may have gotten on the the optics.
    Jun 2017
    I clean the optics but I still have the same issue, im going to try use anti reflective coating spray, yesterdar I use a black sharpie and works a little bit better
    endurance_robots
    Guest
    we tried this method, laser etching
  7. #7
    endurance_robots
    Guest
