I have been using laser machines for over 3 years and I do not have a Clue as to what your talking about??? Are you talking about backlash adjustment? If so its machine dependent.
Hi All
What's your RI Setting?
Is there a body of knowledge that would allow us to populate the RI table with a full range of settings, or is there some maths that we should apply to 'the' setting that works best at a particular speed to calculate other optimal RI settings? Or is it just completely machine dependant anyway so go figure Andy?
Andy
1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
Err thanks - I think - maybe I'm over sensitive but I detect some kind of attitude - this is just a three grand toy - I'm not planning on supplying McLaren or BA with high precision parts anytime soon. If this is typical of so called 'help' here I can go elsewhere, I dont need to be put down cos I bought Chinese!
You may call it backlash,but in RDWorks it's called Reverse Interval, which is a pretty accurate label for what it does as I recall from engineering days!
No RI setting knowledge. This picture was made by me.
