Problem Engraving makes duplicate image.
Results 1 to 8 of 8
Thread: Engraving makes duplicate image.
    May 2017
    Default Engraving makes duplicate image.
    I just got this machine (60w red/black ebay) yesterday. Tried engraving today and it produces a doubled image effect. I've tried with different files and same result every time. I checked alignment and no problem there. It cuts just fine. Any ideas? I've seen similar problems on this forum but the others had issues with the doubled image casted to one side. My problem is that the image is doubled perfectly to the right and left.
    Engraving makes duplicate image.-img_4840-jpg
    Attached Thumbnails Attached Thumbnails Engraving makes duplicate image.-img_4840-jpg
    Nov 2010
    Poland
    Default Re: Engraving makes duplicate image.
    Try to set engraving in one direction first and check any difference.
    CNC lasers, constructions, service
    Nov 2016
    Have this same issue, everything seem to be setup right. Also brand new machine just setup yesterday. Does not make any sense why it is doing this.
    May 2017
    When setting up your scan/engrave settings in RDWorks, change scan mode from x swing to x unilateralism.
    Nov 2016
    Quote Originally Posted by narch View Post
    That's it! Thank you
    Also did you figure out a way to have it not fire the laser when doing a frame to see if it will all fit?
    May 2017
    Haven't figured that one out yet...
  7. #7
    Sep 2005
    Sometimes a loose lens will lead to more or less the same problem. Or mirror.
    Master Electrician - Retired.
  8. #8
    Nov 2016
    Ok so that sort of fixed it but there is now a new problem I can not figure out, x_swing is the only mode that will allow engraving in both directions. I Have look everywhere and played with setting for an entire day, and nothing. Seems to be something with the speed But does not seem to make sense why it is firing the laser twice. Only other post that has anything to do with this problem I can find is this Chinese Redsail x700 with problems. Your thoughts [Archive] - Sawmill Creek Woodworking Community
    Any help?
    Sent an email to the sell to see if I can get this working, without engraving both directions is it is very slow.
