Under the Config menu you will find system settings
You can set the origin and I believe you will need to un-mirror the x axis.
I just received my red and black 60w ebay laser today. Everything is set up and working good, except for the fact that 0,0 axis points are in the top right corner. This is also how the software (RDWorks) is set up. Is this how the machines are configured? Is there any way to change it? Thanks for your help! It feels awkward working right to left.
Usually the 0,0 Machine Home is set where the Limit Switches are located. You can set the Origin for your work anyplace, like mine is set at Center. I just use the arrow keys to move the head to the center of the work and press Origin on the Key Pad. You can set the work piece Origin to be anyplace.
1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
