Problem 40W CO2 Laser, beam internally arcing to anode.
Page 1 of 2 12 LastLast
Results 1 to 12 of 17
Thread: 40W CO2 Laser, beam internally arcing to anode.
    Aug 2015
    Default 40W CO2 Laser, beam internally arcing to anode.
    I just received my new so called "K40" laser and I am having an issue with the laser internally arcing to the anode and causing power loss.
    (Here is the laser cutter I bought)
    40W CO2 Laser, beam internally arcing to anode.-capture-jpg
    I also found this video on YouTube that show exactly what mine is doing.
    I am already using distilled water in my laser but after thinking about it, the bucket I put the water in was pretty dusty when I bought it from Home Depot.
    So I am going to go home tonight, clean the bucket and flush the system with fresh distilled water to see if this goes away but my question is:
    if it doesn't go away what are some other things that can cause this?
    I can return the machine from the place I bought it from but if it can be fixed without to much headache I would prefer to keep it.
    I have a feeling even if I order another one it will have its problems too.
    Attached Thumbnails Attached Thumbnails 40W CO2 Laser, beam internally arcing to anode.-capture-jpg
    Sep 2005
    Default Re: 40W CO2 Laser, beam internally arcing to anode.
    I hate to be the bearer of bad news, but the K40 machine is just a mm or so away from being junk. Some people have got them to work, and others have spent hundreds of dollars and they still are not happy. IF you can send it back, and receive a refund go for it. Then save your money up, Automation Tech out of Chicago and LightObject out of Sacramento sell some good lower cost machines. I got one from LightObject and I was using it just today to do a project for my wife. Works great and its a true 40 watt machine. I just arrived Tuesday but I have been using lasers since late 2013.
    Master Electrician - Retired.
    Aug 2015
    Yes I kind of figured it was to good to be true, usually is. I sent the video to the manufacturer and they told me the laser was firing normal, yeah right!
    So I told them, OK I am not jumping through these stupid hoops, I was dumb enough to buy it but I'm not dumb enough to not know its not working right.
    I am returning it Monday. Unfortunately I don't have much more than $500.00 to spend on something like this so I guess my laser cutting days are done.
    Sep 2005
    Quote Originally Posted by CJG71 View Post
    I hope your get you money back.
    You might keep an eye open on Craigslist and on here sometimes good machines are sold because the owner wants or needs more power. My 40 watt machine from LightObject has a tested at 45 watts Max tube that is 850 mm long. If I can keep the water cool and don't overpower it, the tube may last for a long time. I don't know what you planned to use your machine for, just hobby or making money for an idea? They are having a sale at LightObject right now, but in addition to the machine you will need a small submersible water pump ( I had one from a garden pond project) a air pump and exhaust fan both from Amazon.
    Aug 2015
    I will get my money back no problem, the one smart thing I did was buy it through Amazon Prime and only from a seller that had a return policy. I actually bought the machine to help me make a little invention that I came up with but I figured since I had it I might as well make a little side business out of it and do some etching etc... I was pretty disappointed to find that it doesn't work. I don't really have a lot of money so being able to pick up a good one that would actually work would take me a good while as I can only save a small amount each payday. I am going to try to find a company that will just cut the pieces that I need for now and maybe if my little idea takes off I can buy a better one. I am just trying to get the prototype made so I can get a Kickstarter campaign going and run some ads on Facebook. I will keep my eye out for some used ones though, that might be something that could work for me. do have one other question though... I found a laser tube that actually has metal collectors on it and looks like a good laser tube.
    https://www.amazon.com/2500-3000-40W...40w+laser+tube
    I wonder if I just changed out the laser in the one that I have if it might work? Or do you normally end up replacing just about every component in the thing before it actually does something?
    I really appreciate your input. Thank you very much!
    Sep 2005
    A 700 mm tube can not be a true 40 watt, its the law of physics at work, and a little deceptive advertising. Look at the HV power supply in the unit you have now, and be careful if you break a seal or something they might not take the return. Take the part number off the power supply and do a google for it to get the watt rating. I was lucky on the one I had, not a K40 but the PS was a true 40 watt rated.
    Please go to lightobject dot com and have dealt with them for over 3 years and they are an honest vender. Look around and read a bit. The Forum they run has a lot of info. BTW what are you planning to cut? Other than thin wood or plastic not much is possible with a laser under 60 watts or so.
  7. #7
    Gold Member
    Feb 2009
    I got lucky with my k40, paid 310 for it on ebay, and it worked and decently aligned out of the crate. Just used it today in fact. I did add air assist though.
    Sent from my SM-T813 using Tapatalk
  8. #8
    Apr 2017
    South Africa
    I bought a 40W laser which arced randomly in the inside, between the terminal and the mirror. It resulted in high voltage leaking into the coolant and causing wierd things like the coolant temperature readout blanking out, power loss etc.
    Under close inspection I saw something which looked like a strand of hot glue on the terminal pointing towards the mirror.
    I used a 200mw green laser to melt the base of the piece of hot glue and was amazed that it actually worked. 40W CO2 Laser, beam internally arcing to anode.
    Sent from my F5321 using Tapatalk
  9. #9
    Aug 2015
    I actually got it working "sort of" over the weekend. I got it where is would consistently cut at 70% and around 6 mm/s although that still seems quite slow to me as compared to some of the videos I have seen. You might know though as soon as I got it "sort of" working the "Laser Test" button stopped working now the only way I can manually fire the laser is to push the test button that is on the power supply board next to the red light... I am torn between sending it back now and maybe just trying to make a few bucks with it. I was only planning on cutting (1/8" max) acrylic with this thing so I would have expected it to at least be able to do that. If I decide to keep it I might delve more into the guts of it but for now I am just trying to decide what I should do. I will take a look at the lightobject site again. I looked at it the other day and their lasers seemed a little pricey for my budget but I did see they had a lot of parts etc. I am just not sure what to do right now. I am speaking with the seller and of course they don't want me to send it back and would prefer to just replace parts if necessary but I am not sure I even want to mess with it. I am going to go home tonight and fiddle with it a little more and just see what I can do with it that may be worth while.
  10. #10
    Aug 2015
    Wow I will take a look at mine! At this point I am up for anything that might get it working. Thanks for the feedback!
  11. #11
    Aug 2015
    I was really hoping I would be one of the "lucky ones" but doesn't seem to be the case, although magically the laser started firing somewhat normal over the weekend. I am not sure why but it did seem to work much better, although still not to the level I would have expected. I could only cut 2mm acrylic at around 5-6mm/s seems a little slow to me. Thank for the feedback!
  12. #12
    Sep 2005
    See if Amazon will issue a return. FYI I sold my big lathe and decided to purchase a Mini, just to have one. They had one with good reviews, Prime and "free" shipping what more could I want? Turned out they sent me a return that had been repacked and called good as new. It was not, just junk and it came in busted up so bad I that to redo the box so it would go back UPS. Returned and got a full refund. Thank you Amazon.
