Differences with these two lasers?
Results 1 to 5 of 5
Thread: Differences with these two lasers?
    Nov 2016
    Default Differences with these two lasers?
    I am doing some research on a DIY add on for my 3d printer for a laser engraver. I do not know much about lasers other than the higher the MW the more powerful the laser. I am currently looking at these two laser modules
    450 - 500mW 12V Violet Laser Module-48.75 Online Shopping| GearBest.com
    Powerful Blue Laser Dot Module-56.94 Online Shopping| GearBest.com
    One is a 5v 1600mw laser and the other is a 12v 500mw. Does the difference in voltage change anything? even though the 1600mw is the higher power laser, does the lower voltage change anything?
    Thanks.
    Nov 2016
    Default Re: Differences with these two lasers?
    Anyone?
    Sep 2005
    The voltage is what the diode laser is rated at, the mw rating is the power, the 1.6 watt laser at only 5 volts will have a higher amperage draw. Get the most wattage you can afford to buy. I have a 5 watt rated running at about 4. JTech in Texas has lots of info and good controllers.
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
    endurance_robots
    Guest
    there is always a difference between chinese and origianl laser modules
    endurance_robots
    Guest
