Problem Inaccurate engraving - non exacly engraving
Results 1 to 6 of 6
Thread: Inaccurate engraving - non exacly engraving
    May 2017
    Slovenia
    Exclamation Inaccurate engraving - non exacly engraving
    Hello
    I have 50w china engraver with RDC6442G-B controller the problem is when im engraving on material is like double engraving or like is drunk (can see on foto)
    I have check all mirors and belt and steel nothing. Do any have any solution what iis wrong?
    this problem is when im engraving on x axes or y axes
    Attached Thumbnails Attached Thumbnails Inaccurate engraving - non exacly engraving-p_20170429_005412-jpg   Inaccurate engraving - non exacly engraving-p_20170429_005615-jpg
    Registered Jerrywu's Avatar
    Feb 2017
    China
    Default Re: Inaccurate engraving - non exacly engraving
    you set wrong reverse interval .
    Feb 2017
    China
    May 2017
    Slovenia
    Tank you i will tray
    May 2017
    Slovenia
    Hello
    I solved the problem.
    The problem was bad wire conection on co2 tube.
    And thank you for fast reply.
    Denis
    May 2017
    United Kingdom
    Quote Originally Posted by zeka113 View Post
    Hello
    Denis
    How did you work out that there was a bad wire connection on co2 tube? I have similar issue for not accurate / unclean application for long jobs and trying to fix it!
