Need Help! 40w chinese laser only works on around 25% power!?
Results 1 to 4 of 4
Thread: 40w chinese laser only works on around 25% power!?
    Feb 2017
    United Kingdom
    Default 40w chinese laser only works on around 25% power!?
    I have a 40w k40 chinese laser (UK based)
    I recently run the water to hot and the laser stopped working.
    I replaced the tube, and now the laser will only run on a power of 25%, if i turn the power slightly above that it will not run.
    Will i need a new psu? or is there somthing i may be missing?
    thank you in advance for any help!!
    Feb 2017
    United Kingdom
    Default Re: 40w chinese laser only works on around 25% power!?
    40w chinese laser only works on around 25% power!?-psu-jpg40w chinese laser only works on around 25% power!?-psu-jpg
    Heres a photo of the psu, are there any fuses which may cause this types of problem?
    thanks!
    Sep 2005
    Do you have a mA meter on the tube? It needs to be in series with the ground lead.
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
    Apr 2017
    United Kingdom
    i hope to find out this answer as well as im having the same trouble. i cant run mine over 20% and the Ma meter goes off the chart. i have posted a video on my post..
