you need calibration the reverse interval.
Hi there,
Just unwrapped my shiny new laser (chinese & ebay) and when I etch things I'm getting a double image.
I have used a laser in my local hackspace so I have some experience of operation but not really any maintenance. I've done a bit of a test with masking tape and it seems like all the mirrors are central. It has never not done the double image so I think it must be something like alignment but I'm not sure what to do.
Help?
Edit: Be gentle with the technical language, pretty please.
RD Works
1.
2.system setting
3.for example: speed300 reverse0.06 you need calibration again and again.
4.different speed different reverse interval
you can scan a word to calibration
This worked! It took a lot of tries to figure out the correct setting but I am getting a perfect image.
Thank you so much!!!!!!
you are welcome
Jerrywu I'm having the same problem but I'l using coreldraw and corellaser what can I do this is driving me nuts
Perhaps you could readjust the light path
-Aeon laser
