Hello! I have a huge problem that I am trying to solve since two months ago and can not find the solution. If you can see the pictures in the link below: https://drive.google.com/drive/folde...0U?usp=sharing You will see a wave that is doing the machine when I cut at speed 25. I use LaserCut. Thank you in advance. Best Regards.Similar Threads:Problem- 40w Laser - Slanted Edges On Two Sides When Cutting CNC Laser Cutting - Edges not square ??Newbie- problems on Trumpf laser cutting machine Laser cutting Delrin, getting sloping edges Metal laser cutting machine ventilation problems
Loose belt or possibly a bad bearing in one of the idler pulleys.
1. About the line wave you can lower the X axis maximum acceleration. 2. The cutting graph I think you need recalibrate the laser from 2th reflecting mirror to 3th.
View Tag Cloud
Forum Rules
