Normally you use a bitmap file for engraving. Are you importing a .txt file?
HELP. I have a new 80w CO2 Chinese laser. I put a simple text file in RDworks v8 and upload it to the controller/ The output is just a solid burned line no matter the power or speed settings. When I change the file from "Scan" to "Cut" it does burn the text but connects all of the letters together with a burned line. I really think this is a setting problem of some kind, but I have tried everything.
Frustrated in East Texas
- Need Help!- Lasercut 5.3 downloading to DWin 640 80watt
- Laser cutter software RDworks v8 tutorial 10 How to Engrave a Photo From Thunderlaser
- Need Help. Does anyone have Software that wiil work in a POS Chinese 6090 80watt
- New Machine Build- ust pulled the triger on a G.Wieke LC1290 80Watt
- Looking Feed back on WKlaser Model 6090 80Watt
can I see the file your trying to engrave
that doesn't tell me anything can you post the file in corel x5 or AI or dxf
Try to engrave on MDF or paper attached file.
It is circle + square (no fill) and scanned m67 letters. Roughly 1"x2" in size all.
Polish @ Éire
This file is .rd for mskaggs67 (not for you) to he can put it directly on USB stick and cut/engrave. This way he can check and confirm his machine is ok (if cut/engrave this file properly).
Polish @ Éire
