Need Help! 180w optics upgrade questions
Results 1 to 3 of 3
Thread: 180w optics upgrade questions
    May 2016
    Default 180w optics upgrade questions
    Upgraded 100 watt CO2 laser to 180w. Orginal optics are 20mm focal lens. Having issues getting good cut. All optics have been aligned, cleaned. New power supply installed. In testing the cone below the focal lens is getting really hot. Re-confirmed alignment in down tube is good. Could it be the focal lens is too small in diameter? Do we need to upgrade the down tube, focal lens, and mirrors to larger diameter? Stumped on this one! Any suggestions greatly appreciated. This machine is a Automation Tech Chinese laser.
    Member ArgusLaser's Avatar
    Aug 2016
    China
    Default Re: 180w optics upgrade questions
    Dear Gshimer,
    The laser beam of 180W tube is bigger than that of the 100W, you need use the 25.4mm diameter focal lens.
    Warm regards
    Eric
    Sep 2012
    If the nozzle is getting hot, the beam is clipping it. Gene
    4x4 shopbot with chicom water cooled spindle
    3x4 130watt chinese laser
